TdiRabbi
So I bought this Golf without the AC working. Refrigerant is charged. Found AC compressor clutch won't engage. Had no power going into clutch. All fuses were good. Read that the FCM is a common failure, so I replaced that. Now I have 12+ volts and good ground going to clutch. Tested AC again but still doesn't engage clutch. Checked resistance to coil and it had 4ohms which seems to be the spec according to other threads. Seems like maybe a bad clutch?
Looking for some insight on the repair, and possibly recommendations on a decent clutch or compressor kit for sale out there.
Thanks!
Thanks!
