Eco Driving
Driver: don4sail
Miles: 602
Gallons : US 9.6
Model Year: 2003
Model: Golf GL TDI
Tranny: M
Fuel Type: UKSD
You are allowed to put more than one fill up in a post, so long as each fill up conforms to format.
MPG: 62.7
Hint on entering your data - after the colon ( ":") put a space.
US GALLONS AND MILES
TRANNY TYPES:
(x) A = x speed automatic
(x) M = x speed manual *
DSG = direct-shift gearbox
CVT = continuously variable transmission
* if you have swapped in a taller 5th gear please noted this (ie: 5M w/.681)
FUEL TYPES:
Bx = biodiesel - x is the percentage of bio
Biodiesel use equal to, or more than B20, will be indicated in GREEN.
ULSD / LSD / D2 = normal petroleum based diesel
Also please note if it's winterized[/COLOR]
- please note if you are using a fuel additive (ie: ULSD +PS)
- - Power Service (PS); Stanadyne (ST); Redline (RL)
Posts not in format will not be tallied / corrected.
Please do not go back and add additional fillups to a post. Multiple fillups per post is fine as long as all fillups are in format. If the driver name is not the same as your post name - this will be considered "Not in format" and will not be counted. Only exceptions would be "and spouse" etc.
http://pics.tdiclub.com/data/500/TDI_Mileage_upd_9-20-08.pdf
[/QUOTE]
