2001 TDI Jetta and the glow plugs do not come on until after the engine has started. We have followed the troubleshooting threads for glow plugs and everything checks as OK to the last step which is to replace the temp sensor. We have tried 6 different temp senors and still the same issue. The glow plugs work when the temp sensor is unplugged.
Where to go from here? Which wires on the temp sensor are for the glow plugs?
Thank you
Thank you
