After much searching an a long wait, we received two turbos that are used on the A5 with engine code BMM in Europe. Here it is:
This is off a 2.0 liter TDI that makes 140 HP stock. And it's a Garrett, not Borg-Warner. Here the two are side-by-side.
Although it doesn't appear a huge amount larger, both hot and cold sides are bigger than the stock turbo. And our thinking is that if it can make 40 more HP in a stock application, maybe it'll get a tuned BRM with stock injectors into the 160-170 HP range.
One of our major objectives easy installation. As best we can tell this will bolt on, intake and compressor exit will attach as normal. It does appear it would need a different downpipe as the turbine exit is in a slightly different location. But we suspect that people who want to upgrade to this turbo may want to upgrade exhaust, too. And the oil feed line location is different, as is the fitting.
The actuator doesn't have the feedback loop included, but I believe that's something a tuner can take out of the picture. Since the actuator and lever to the vanes is in an entirely different location, it doesn't look like an actuator swap will be easy.
I honestly don't recall the pricing (I ordered these in April!) but I think it was a few hundred more than the stock replacement. Given the ease of installation it may end up being a pretty economical upgrade.
We're eager to get one of these in a car and do a dyno with the appropriate tune. I think we already have a volunteer!
