RyanH
Having a weird problem with my 2006 Jetta, 241k miles.
First thing I noticed was engine speed rising or falling 30 or 50 rpm or so for a second or less at a time. At first I only noticed it because my head would bob a little - very subtle. Either this only happens when I'm above 65mph, or I'm only noticing it then. Changed the fuel filter, symptom persisted.
Now I'm having episodes from time to time when the thing just loses its mind. The cruise control drops out, the wheel slip light comes on, the oil light comes on, and the alarm sounds. While this is going on, the tach needle falls to zero for a few seconds, comes back up to where it's supposed to be, falls, back and forth. Apart from the dash lights and alarm, everything seems fine while this is happening. That is, the car runs and drives okay.
During the most recent episode, a new development: an amber light came on in the tach and went out again so quickly I couldn't see what it was. I then almost immediately lost power and was unable to maintain speed for around three seconds before power returned and everything seemed fine except for the tach needle, slip light, and oil light.
Every time this has happened I can stop the car, restart and all is normal again.
The only thing the local guru shop could find wrong with it was a faulty camshaft position sensor, which they replaced. The car runs a lot better in general with the new sensor, but the engine speed blip thing persists. I expect to experience further cruise/tach/warning light episodes, but haven't had one yet since I got the car back with the new sensor.
Anybody had anything similar? Any ideas? Thanks.
