Jakub
Hi I have a 2006 Volkswagen Jetta TDI. My airbag light is on in my horn does not work. I tried switching airbags into leading the code using VagCom but that doesn’t work. Still gives the same codes. Can the issue be a steering wheel angle sensor? Or something else? Does anybody know where this horn fuse location is?
The codes for the air bag are
01587 igniter 2 for airbag driver side (n250)
00588 airbag ignitor, driver side (n95)
And horn code is
00906 horn h1
009 open or short to ground
Please help thank you
And horn code is
00906 horn h1
