1.6 TDI Judder at 50mph in 6th gear
Steven715
Bedfordshire
B7 Passat Estate Executive style 2.0 TDI 140
Hello there I am new to the forum (Long time listener first time caller;)) I am very pleased to be a part of the community. :D
Ok down to my problem My 1.6 TDI has a judder when cursing at a speed of 50mph in 6th gear I have also noticed the same judder at around 40mph in 5th although not as strong as in 6th. This usually happens when I am just cruising along the road no real load on the engine this can happen on every trip so much so that even passengers notice the judder.
I know it not the DPF regenerating as I have checked in VCDS and the DPF last regenerated at 110 km ago. The engine is up to temperature with the oil temperature up to 80 degrees C.
The Car has done 58K miles and there is no fault codas stored for the engine however I do have a couple one of which that may apply is the parking break however there is no indication that there is a problem on the dash.
The car is still under warranty only just (6 Months left or at 60k miles So less than 6 months) VW will charge me if they cant find anything and at £110 I don't want to be fobbed off and £110 lighter.
So I welcome your thoughts on this.
Many thanks steve.
Code:
Wednesday,29,January,2014,17:43:23:58321
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: xxxxxxxxxxxxxxxxx   License Plate: xxxxxxx
Mileage: 58528   Repair Order:
Chassis Type: 3C (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 61 62
          65 72
 VIN: WVWZZZ3CZCE005744
 01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 FS    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 9196
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00194016032501080000
   Shop #: WSC 00015 115 00000
   ASAM Dataset: EV_ECM16TDI02103L906023FS 003006
   ROD: EV_ECM16TDI02103L906023FS.rod
   VCID: 7CD91029F708B6FEC8B-8029
 No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 3AA-614-109.clb
   Part No SW: 3AA 614 109 AB    HW: 3AA 614 109 AB
   Component: J104   C2 450M V44F 0022
   Revision: --H07---    Serial number: 00000004269690
   Coding: 0002983
   Shop #: WSC 05311 000 00000
   VCID: 6DFF2D6D74722F764F5-8038
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 DT    HW: 5K0 907 044 DT
   Component: Climatronic   H17 1010
   Revision: 00001003
   Coding: 0000000003
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 8021E4D91BE0521E143-80D5
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 D    HW: 3AA 937 087 D
   Component: BCM PQ47 H    413 0455
   Revision: BB413001
   Coding: 000000000000000000180080140081E403510088426D81606480C7200041
   VCID: 3B5BD335BA8671C6811-806E
    Subsystem 1 - Part No: 3AC 955 119
   Component: Wischer 10051  26  0612
   Coding: 00B795
    Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 300511 05  54  0403
   Coding: 0230ED
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__102 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PABCE3C
   Coding: 0012338
   VCID: 4CB980E92F28C67E38B-8019
    Subsystem 1 - Serial number: 6332MTS679401221
    Subsystem 2 - Serial number: 6342MTS620861211
    Subsystem 3 - Serial number: 6351HTS6L6AR1AKR
    Subsystem 4 - Serial number: 6361HTS65A833AKJ
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C9 953 501 BN    HW: 5K0 953 569 AB
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110523300341
   Coding: 1182250000
   ASAM Dataset: EV_VW360SteerWheelUDS A03004
   ROD: EV_VW360SteerWheelUDS.rod
   VCID: 76CD0201C924ECAEBEF-8023
    Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Component: E221__MFL-TK6  H06 0022
   Coding: E20000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3AA 920 970 E    HW: 3AA 920 970 E
   Component: KOMBI         H03 0607
   Coding: 461F00
   Shop #: WSC 05314 115 00000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 354FC50D94A2A7B6775-8060
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway H41 1620
   Revision:   H41       Serial number: 180511F1000530
   Coding: 462007
   Shop #: WSC 05314 000 00000
   VCID: 3957C93DB0BA43D693D-806C
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0399
   Revision: 00043000    Serial number: VWZCZ000000000
   Shop #: WSC 131071 1023 2097151
   VCID: F6CD820181246CAE3EF-80A3
    Subsystem 1 - Part No: 3C0 905 861 J
   Component:    ELV          029 0380
   3C0905861J     ELV          029 0380
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
   Component: SG EXT.PLAYER H13 0240
   Revision: A1001003    Serial number: 7660118903
   Coding: 020000
   VCID: 2977197D401AF356E3D-807C
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 3C0 035 279 B    HW: 3C0 035 279 B
   Component: RNS315-EU   H32 0263
   Serial number: VWZAZ2L3355182
   Coding: 040004010400110000019002
   ASAM Dataset: EV_RNS315EUV2UDS A01004
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 22650E51352C200EA27-8077
    Data medium:
   Subsystem 1 - Part No: 3AA 919 866
   Component: EUR_W_0031  0031
Address 42: Door Elect, Driver (J386)       Labels: 3C0-959-70X-GEN4.clb
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0534
   Revision: 12110009    Serial number: 0002906503
   Coding: 0202B7
   Shop #: WSC 05311 115 00000
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
   ROD: EV_TSGFPQ35BRFVW46X.rod
    Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0407
   Serial number: 00000002187549
   Coding: 000290
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 194    3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: 3449F80957D8BEBE40B-8061
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ47 ELV 043 0631
   Coding: 0191020052830E76300494157C085FCE105C01
    Subsystem 1 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HORN H11 9005
    Subsystem 2 - Part No: 3C0 951 171 C
   Component: Neigungssensor  004 0611
    Subsystem 3 - Part No: 3C0 951 171 C
   Component: Innenraumueberw.004 0611
Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
   Part No SW: 7N0 907 532     HW: 1K0 907 951
   Component: EZE_2         H41 1620
   Coding: 00000008
   VCID: EFC3B7653E7E5D66FD9-80BA
    Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
Address 52: Door Elect, Pass. (J387)       Labels: 3C0-959-70X-GEN4.clb
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0534
   Revision: 14110009    Serial number: 0002918500
   Coding: 0202B6
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 364DC20189A4ACAE7EF-8063
    Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0407
   Serial number: 00000002201614
   Coding: 000290
Address 53: Parking Brake        Labels: 3AA-907-801.clb
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000024023
   Coding: 0022167
   VCID: 354FC50D5CA2A7B6775-8060
 1 Fault Found:
02442 - Function Lamp in Control Head
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01111001
                    Fault Priority: 6
                    Fault Frequency: 14
                    Reset counter: 79
                    Mileage: 90619 km
                    Time Indication: 0
                    Date: 2025.14.01
                    Time: 15:02:42
              Freeze Frame:
                    Voltage: 12.20 V
                    Count: 79
                    Speed: 0.0 km/h
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H41 1620
   Coding: 030B085A
   VCID: F1C7B11D284A4B96EBD-80A4
    Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0180
Address 65: Tire Pressure (J502)       Labels: 3AA-907-273.clb
   Part No SW: 3AA 907 273 B    HW: 3AA 907 273 B
   Component: RDKBERU30     H08 0008
   Serial number: 10000000036720
   ASAM Dataset: EV_RDKBERU30 003010
   ROD: EV_RDKBERU30_SE36.rod
   VCID: 334BFB159AD6B986591-8066
 1 Fault Found:
12656671 - No Communication with Diagnostic Gateway
          U0146 00 [008] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 87
                    Mileage: 93035 km
                    Date: 2026.14.14
                    Time: 16:43:26
End   ---------------------------------------------------------------------
Rico567
Central IL
2013 Passat TDI SEL Premium (Turned in 7/7/18)
Well, sounds interesting, but most of the folks on this forum are U.S. and Canadian drivers, and so won't be much help, I'm afraid. We don't drive the B7 Passat that is sold in Europe, we have the NMS Passat made in Chattanooga, TN. Not only is the car itself different, but our TDI is the 2.0 CKRA engine, not the one in your car. In any case, good luck!
ABS
South Central Minnesota
2014 Passat SE TDI, 6MT
Going out on a limb here, since we do not have the 1.6L TDI stateside, but a few suggestions anyway.
First, did this just start? If so it could be as simple as bad fuel..
Fuel filter - when was the last time it was replaced.
Does it happen when you use cruise control? If not, the Pedal TPS could be corroded...
EGR
MAF
And my last thought would be turbo related, an actuator solenoid perhaps...
TDI2000Zim
NJ
VW hat meinen '14 Passat TDiSE getötet.
Do any LIGHTS flicker almost simultaneously, for a short time, like these three:
Steven715
Bedfordshire
EGR
MAF
Thank you both for the quick reply's I did not know that you don't have the B7 there I will look up the NMS.
"Did this just start" to be honest I have only had the car a month I am the 2nd owner and it has done it since I have had it although it does seem that it's getting worse.
Fuel filter this was changed at its last service so the car has only done about 4000 miles at the most (without looking)
"Does this happen when you use cruise control" hmm good question I will try it on the way home from work tomorrow and report back.
EGR I thought this could be a possibility I may try and take some measurements with VCDS the same with the MAF
As for the fuel I thought this initially as I used 1 tank of supermarket fuel I am now done about 120 miles on BP Ultimate hopping it would "clean" out the engine
What I will try I think is top off the tank again with BP Ultimate on Friday and add some additive to the tank give it the best chance we are going on a 200 mile round trip on Saturday so it will give the additive a chance to work.
I thank you once again as you have given me some ideas to try. I will as always report back.
Regards Steve.
Steven715
Bedfordshire
What does the EGT do while this is happening?
I don't know at the moment but I will add that to the list when I do a log. I am working over the next 3 days 12 hour shifts so I won't be able to look at the earliest on Sunday. I will keep you posted and once again thank you all so much for the suggestion.
Steve
Springfield, VA
Is your car a manual, a 6 speed DSG or a 7 speed DSG? My first thought is that you have a clutch or flywheel issue (possible with any of the above transmissions transmissions).
Steven715
Bedfordshire
It's the 6 speed manual I hope it's not the DMF though :( if its the DMF then I would have expected the juddering to be more proponent and maybe in all gears even idle.
As an update I tried what putting the car in cruise control and I did notice it again more so when the car was accelerating up a slight hill. Looks like I will have to call VW and see what they have to say.
I will do some poking around in VCDS and make a few logs and see what I can get.
Thank you once again to all your help I will keep you posted.
Steve.
Steve.
Steven715
Bedfordshire
Follow up
Hello there as promised I have given my laptop a ride in the car and logged some results with VCDS I have logged things that I hope is relevant.
There is 2 log files the second one has bank A and B exhaust temperatures.
The conditions of doing this test I had been raining the lights was on but turned off in auto on way back the external temperature was 7.5 Deg C (although the temperature don't seem to matter) The trip was 10.6 Miles (17.2KM)
Log file 1: Ok so to note that after 4 minutes (240 Seconds approx.) into my trip I had the juddering doing 50 MPH in 6th gear I done it at 50 in 6th as this is where its more noticeable.
Log file 2: I pulled over into a layby and added Bank A,B exhaust temps back in this log file I guess the juddering was at 90 seconds approximately (I had to go round a roundabout to go back on myself) and the juddering was evident for about 120 seconds.
All the information is approximate I tried to take notice of the time of when the juddering happens.
And form information I have now booked the car in to be looked at on this issue and the first thing they said on the phone was
Dealer: Well 6th gear may be a bit high for the speed
Me: I agree but the indicator tells you to change up at 45mph and if I cruse at 45mph in 6th its ok the juddering is between 50-55
Dealer: I hope we can find something
Car is booked in in a couple of weeks time so we will have to wait and see what they say.
As always if there is anymore information that is needed please let me know and I will try and get that information.
I have uploaded the files to my dropbox account hear are the links I hope they work ;)
https://www.dropbox.com/s/b9420kd217csj3r/Log 1.CSV
https://www.dropbox.com/s/ehrq6h8yzunalf7/Log 2.CSV
Many thanks Steve
50pascals
Rochester, NY
2014 A6 3.0 TDI Prestige, prior was a 2013 TDI Passat SEL Plus
What rpm are you turning when this happens?
Is this the same engine as a Seat Altea?
Steven715
Bedfordshire
Hello there engine speed is about 1300 rpm at 50 mph. I believe it's the same engine as the Altea I will look for an engine code in the morning and confirm.
In a way I hope it's my fault that I'm in 6th gear and its not really suited but that kind of bothers me when the car itself recommends going up a gear at 45 when cruising so the gearing / engine must be designed for this?
Like I said before why don't this happen at 45 mph?
50pascals
Rochester, NY
I am thinking you are lugging the engine. Essentially this means the cylinders cannot make enough power when they fire and the flywheel does not heave enough stored energy to propel the car between firing pulses. So the engine is rapidly decelerating between firing pulses, and the pulses are hitting a piston that is nearly unable to be moved and only accelerating slightly.
It may tell you to upshift at 45, but that would be assuming light load on flat ground. Mild acceleration on a downhill might be fine at that RPM.
The reason I asked about the Seat Altea (and I believe it is the same engine) is because I drove one for 10 days in Spain this past summer. I never used 6th gear until I was on the highway. Due to a shimmy from the tire or wheel I only ever went 65mph. Once on the highway I never downshifted. This was on the AP-7 along the Mediterranean coast.
Around town I shifted it at 2000 to 2500 rpm. We usually had 5 people in the car.
My rule of thumb for ANY shift light is to ignore it. They program it to meet maximum fuel efficiency, at the expense of the engine and driveability.
Steven715
Bedfordshire
Sounds like you maybe right I have been playing on different roads including going down a slight hill and it will even do it then its stronger at 55 mph though and I even noticed it in 4th gear at 30-35 mph only very slight.
Like you I change up a gear at around 2000 to 3000 rpm depending on road conditions and how many passengers I have.
I have now started to avoid using 6th gear unless I'm doing 60mph at this speed everything seems happy.
My appointment is next Wednesday so I will report any findings if any.
On a side note I am fully aware that this is a completely different car I was observing a 2010 2.0 140bhp 6 speed DSG Golf. When I drove the car I noticed that the gear changes are the same as what my shift up light I drove normally and the DSG changed up into 6th at 45 if cruising and at 50 55 everything was as smooth as silk even at 45 it was happy this is a car that has done 101k miles on the clock.
I will keep you posted on what happens next week. Even if I am in the wrong! :)
I really don't believe the car should do this I know what it feels like when you select a two higher gear for the road conditions and I can do this with this car and the results are 2 very different things.
Steve.
Passat 1.6 TDI sport estate Bluemotion
mihneagabriel
Kingwood
2009 Jetta
Steve.
I agree with what 50pascals said.
Keep in mind that the 1.6 is quite a bit different from the 2.0 we have here and makes less power. I would never shift that early. My friends 2010 gti (2.0T gas engine) tells him to shift at the weirdest times. It makes no sense and he just ignores it.
And although the dsg might shift into 6th at that speed, keep in mind that the gearing ratio is probably different
Does it feel sort of like a new driver learning to drive standard? It's sort of the same principle where there isn't enough power basically.
Good luck. Keep us updated
Steven715
Bedfordshire
Thanks for the reply I will let you know what happens. I think I may disable the gear change in vcds if I can I will get it checked out anyway as I am loosing a small amount of coolant I have toped up the expansion tank 3 times in 1000 miles once from near empty enough to bring on the light so I will get it looked at at the same time.
Keep you posted
Steve.
50pascals
Rochester, NY
I just found out I will be in London next Weds, Thurs, and possibly Friday for work and sightseeing. I'll give you my unbiased test drive impressions....
Steven715
Bedfordshire
Hi 50pascals I am up for that what areas are you planning on visiting? I am in the Bedfordshire area and I may be off work to thank you for the offer although this Wednesday coming its going in to the dealer to be checked out.
Steve.
Steven715
Bedfordshire
Ok just got off the phone from VW. They found that my coolant leak was my water pump leaking and it has leaked over the Cambelt so Cambelt and new water pump under warranty just for information for others car is at 58k miles
They could not detect my judder however the chap that took my information on how to get it to happen so I told the lady on the phone how to get it todo it. If they can't detect it then I will drive it with them so thy can see.
However saying that they have detected that one of the wheels need to be re aligned so I have asked them to go ahead £120 to get that done and also the fuel filter they said needs replacing. So I hope that these two alone will cure the problem.
I will keep you posted they are finished for today. Should get the car back tomorrow afternoon.
Steve.
Steven715
Bedfordshire
Got my car back and all is sorted looks like it was a problem with the wheel alignment that was causing the juddering.
I want to say a big thank you to you all that commented and helped.
Many thanks. Steve
Steve.
jakobkoester
Denmark
Skoda Superb 1.6 TDI, Skoda Octavia 1.9 TDI
Juddering...
Hi Guys
I experience exactly the same juttering on my 1.6 TDI Skoda Superb with manual gearbox. Everything below ~1800 RPM often results in juddering.. Eg. when crusing on a flat road in 5th gear, the car might go into "juddering" mode, almost a self-amplifying situation in which you might have to deactivate the cruisecontrol to stop the vibrations.
Tried exchanging the wheels to my wintertyres with no luck.
I´d really like to measure these vibrations - do you know if there is any advanced measurements pointsin VCDS that contains X,Y,Z measured vibrations, so we might be able to graph the vibrations to check the frequency thus comparing to wheel diameter / rpm etc..
thanks
Steven715
Bedfordshire
Mine did stop a few days but it came back again I go so fed up with it that I got new 2.0 TDI and this does not do it at all. I think that it's a problem with the injectors or the EGR valve from what I read up on it I hope you get it sorted out. Steve
jakobkoester
Denmark
Hi Steve.. Where did you read anything about that ? If it is an EGR issue / injector issue, then it could possibly be fixed by performin a change of injection values and EGR adjustment. (Tuning of the vehicle) ...
Unfortunately I cannot afford another car currently (a new Skoda Superb with the 2.0TDI costs in the region of 35.000£ in Denmark, so I have to stick with the current car for another three years :)
Steven715
Bedfordshire
Hi jakobkoester I will do a search when I am on my computer for you I know I read many threads regarding the same problem we have. To be honest I was so unhappy with the power output for such a large car I felt that lithe engine was underpowered it was never going to please me but the judder was the last straw. Before I got rid I tried using an injector cleaner mixed in the fuel tank with driving the car hard at higher revs. I also tried 3-4 tank fulls of the more expensive diesel but to no avail. If I was you it won't cost much to try those and see how you get on.
I will get back to you with some links. Steve.
kwiatekch
Chicago
2012 Jetta 2.0TDI
whats the fix for it ?
looks like this threat is couple of years olf but what is the fix for it ? have same problem with my 2015 2.0 passat cvca
Steven715
Bedfordshire
Hi unfortunately I never found a fix, I do wonder if something like the EGR valve was starting to clog up but this is just a guess.
I hope you find a fix, I read that many articles on this subject I couldn’t find the one for the previous poster.
