shoebear
- Joined
- Aug 1, 2002
- Location
- Colorado Springs, CO
- TDI
- 1998 Jetta, 2003 Jetta Wagon, 2005 New Beetle, 2013 Sportwagen
My 03 Jetta 5-speed had a leak at the right drive axle where it exits the diff. I needed to change the right axle anyway, so I went ahead and removed the drive flange/stub axle in order to change the seal.
The seal on the right has an attached metal seal flange - Google part # 02J409528A for photos to see what I mean. I got the replacement seal from idparts.
I used a seal puller to remove the seal/flange assembly, but to my surprise, the seal popped loose from the seal flange, and now I can't figure out how to get the metal flange itself out. I've tried prying it with a prybar, but there are not many decent fulcrum points. The seal puller is no use, as there is nothing on the inside of the flange for the seal puller to hook onto.
I thought about removing just the seal from the new flange/seal assembly, but I suspect I would damage the seal getting it out. Besides, the seal and flange are intended to be replaced as a unit.
I'm stuck until I can figure this out. I would appreciate any tips or tool pointers.
Thanks!
Thanks!
