aloha Every one! new guy here have a few TDIs in my possession with varying condition but all none runners.
so today I'm working on a 1997 <-(i think) Passat not sure it it is the 1z or Ahu
Either way I had tried to start it by priming the fuel pump etc with no luck, I had fuel to injectors etc and a little bit of white smoke while cranking,
that led me to think the timing belt may of jumped so I went ahead and removed all the necessary bits to check the static timing
and it appears as there is No flywheel mark for timing.
I got the cam with cyl#1 lobes creating a V and my pump pin in, But the cam lock won't fit, and like above No flywheel mark.
What would you do next? any way around the flywheel mark.. how odd is it that there isnt one?
