I've now worked on
@SeattleMK4Golf_BEW car a second time with needed time to give it a proper run down. For the love of god never take your vehicle to Mouse Meat in Tacoma Washington. Vacuum pipe to brake booster was very badly cracked causing major braking issues. His new turbo was installed with the rod length set at 15. This likely with some help from the vacuum issue at some point caused an overboost situation which resulted in him popping the turbo piping to the intercooler. Rather than dropping the pancake pipe to snap the pipes back together properly Mouse Meat wedged it back together best they could and ran a sheet mettle screw through the inter cooler intake and the connecting pipe. Bew's inter cooler needs patched and he needs a new hose. Confirming his cam seal was either very defective or they buggered up the install. I ended up replacing his cam sensor as it was throwing CELs but I wouldn't be surprised if it was due to all the oil coming down. They failed to use an actual egr block plate on the egr side deleting his egr cooler, cobbled together junk they used was leaking badly. His car also needed a bunch of basic maintenance they didn't catch or recommend, but mainly a shop that damages parts, installs things incorrectly, and fails to catch major safety issues like a split brake booster pipe should not be on this list INMHO. I did tell Bew he could/should take the car back to them to TRY to get them to fix the cam seal, but he would need to check torque specs and his torsion value afterword, and after that he should never go there again.
TLDR: Mouse Meat in Tacoma does shoty shaddy work don't take your car there if you care about it.
