flashing brake light in cluster
TdiDubing
PA
Aight so the past couple of days have been hell and it dones't seem to clearing up.
background just so people know the whole story.
05 PD
car got chipped w/ RC1+ @ 57,xxx
did an oil change & fuel filter at 61,xxx and didn't prime the filter enough so it wouldn't start. pull the valve cover because i was stupid and than replaced that and pulled a glow plug got it to crank over, seems like the pump that turns on before you crank the car is a little louder now.
got a glow plug code P0672 & P0672 P
along with a P2564 & P2564 P
fix the glow plug by just pushing the harness all the way on
now going home yesterday and coming to work I had the brake light flash and a loud (you are out of fuel sound) some on. pulled over tried to scan w/ OBII scanner (no vag-com) and didnt get anything. than it just stops. So i drove to work and hear I am maybe one of those codes could have caused it. This came up while going up hills both times, ~10-14 psi @ ~2200-2500 rpms
Also I got the P2564 & P2564 P codes again on the way to work w/ a CEL
I understand that is the n75 (i think) and it might need to be replaced.
If somebody could help me out please?
TdiDubing
PA
aight ill give that a try after work. dont know how that would have gone down because i did SS brake lines and near fluid last fall and I would have expected that to occur sooner. But I will check, thanks
any other thoughts?
2004STARWARSTDI
LAKELAND, FL
2004 Platinum Gray GLS Jetta / 2006 Silver Jetta with DSG
Just a thought but did you get your brake light switch replacel with the new Green one? There is a factory recall-800,000 plus VWs involved!
