josh8loop
- Joined
- Sep 15, 2009
- Location
- Vero Beach, Fl.
- TDI
- 2002 VW Jetta TDI Manual(performed 01M to 5-speed swap) - 183,000 miles and climbing!
DF,
Hopefully you got your car issues sorted out on the tensioner/alt pulley deal. This weekend while driving(my wifes gasser as mine is under the 01m-5 speed knife) I was thinking about our issue with the fans kicking on too early for our "Hybrid" T-stats. I was able to look at the Bentley, and it seems that we can cut one wire on the radiator thermal switch and install a toggle switch which will disable the Stage 1 fans from coming on. This will render the Stage 2 fans operable, and also the fans would be operable when required by the AC but the low temp slow fan kick on would be disabled. If I wanted to go back to normal I could just flick the switch back one, and all would be back to stock.
Stage 1
Switch on .......................197-206 deg F(92-97 DegC)
Switch off........................183-195 deg F(84-91 Deg C)
Stage 2
Switch on ........................210-221 Deg F(99-105 Deg C)
Switch off.........................195-208 Deg F(91-98 Deg C)
In the latest days testing the "Hybrid" T-stat I did notice the fans kicking on, so I know that is sapping some MPG's from my numbers. Looks like this will be an easy way to make our fans not kick on until it reaches 210 Deg F.
Stage 1
Stage 2
