tampabug
Since I purchased the car the heater /ac controls do not light, all blank. I'm not sure if they are suppose to, if so what's a good way to remove the panel and check on the connections.
tampabug said:Since I purchased the car the heater /ac controls do not light, all blank. I'm not sure if they are suppose to, if so what's a good way to remove the panel and check on the connections.
I did this two days ago. if you can't find a peice of tubing to grab this, ask for some scrap from a hardware store or the auto parts store... it is not a big hose either... and you only need two inches. You can also wrap electrical tape around the end of your pliers to protect the plastics and provide better grip.McBrew said:Push a piece of rubber tubing over the bulb and pull it out.
