manganos
I've looked all over and can't find a manual how to drain the fuel filter. Can someone post how. It is easy on my 03 Cummins but I'm unsure of what the procedure is here. Thanks, Chris
How long does the Cat filter last? 20K? 30K?Look into getting a CAT 2 micron fuel filter. I just converted mine to one of these this weekend. It's a much better filter.
www.lubespecialist.com is where you can buy the adapter and filter.
__. I have about 45K on my first CAT filter now. No problems so far (although I'll be changing it out with a new filter this week - I found them for a little less than $11 at a CAT dealer in Emporia VA). I'm a bit more concerned with clogging in cold weather at higher mileages than the higher mileage itself.How long does the Cat filter last? 20K? 30K?
