drawred
I have a 97 Passat with 103K mi. It ran fantastically for the first thousand mi. then quickly deteriorated. There are no engine lights on and it idles as well as ever. The problem is when a load is put on the engine. When the engine is cold it stumbles, recovers then stumbles, until it warms up. At this point it is not so much an actual stumble but like turning on and off the power. It will go along for several seconds on more power then the power is noticeably less. When the power loss comes there is a distinct buzzing sound that can be heard. When the power returns the buzzing stops. I dont believe the car has nearly the same power as before the problem occured. I am so new to TDI's that I really don't know where to start. Any help would be greatly appreciated.
