2001 golf tdi iv spent about 4 days already trying to get to the vottom of this but so far no luck..
Symptoms 1st time pressing the brakes i almost get perfect respond releas and try again very hard pedal and bo brake..
Thisgs that iv already done
Changed the vacuum pump tested there about 25 psi sucking pressure.
Changed the hard plastic hose that goes to the booster.
Changed the booster itself 2 times ? 1st change it was leaking so o went and got 3d one which seems to hold pressure
Changed master cylinder
Flush all brake linesand abs i even unscrewed the lines from abs..and blow them with air to make aure therea nothing left
Still same thing no brakes...what do i do next ....im dying with this thing ?
