Hard starting when warm!!! SOLVED!SOLVED!SOLVED!!!!
ok....VW 1.9 Golf GT TDI 1999...milage 114k
when the car is cold i turn the key on and the glowplug light comes on for a few secs then the car starts as normal.
IF the car is warm then i put the key in and the glowplug light comes on for a split second and then the car will crank over for about 5 secs before actully starting! (it will ALWAYS start, but only after about 5seconds of cranking)
If i unplug the coolant temp sensor then the car will fire up straight away (a split second of cranking) but also gives off a little cloud of black smoke for the exsaust)
I have changed the coolant temp sensor, the starter motor and the battery is ok.
I have recently had the timing belt changed/and a full service and was told the timing is smack on. (from rkerns advice, i will get another garage to check this properly)
Please please please can someone help with what this problem could be? this is driving me insane!!!
Thanks in advanced.
Thanks in advanced.
