Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old September 21st, 2018, 13:25   #1
doubledown10
Default Torx Screws
I'm sorry if this has been covered before, and I couldn't find the appropriate thread, but here goes. I replaced the Intake Manifold Runner Control Motor in my 2010 TDI Jetta. I dropped one of the torx screws and it's now gone forever. It's on there pretty securely with just the one. But does anybody know what size or part number those screws are? I would feel better with two in place. Thanks in advance for any help. And again, sorry if this has been covered before.
doubledown10 is offline   Reply With Quote
Old September 21st, 2018, 16:31   #2
Rob Mayercik
maybe a junkyard would let you grab those screws off a wrecked car?
2002 Jetta GLS TDI Automatic
Baltic Green/Beige Leather
Rob Mayercik is offline   Reply With Quote
What size are the torx screws in the rear hatch mechanism? dclark TDI 101 3 April 18th, 2010 10:05
Torx screws: steel or aluminum? dqa VW MKIV-A4 TDIs (VE and PD) 1 May 16th, 2005 19:20
Where to buy Torx Screws for plastic skid plate? robere VW MKIV-A4 TDIs (VE and PD) 9 January 21st, 2004 11:02
Torx screws & door strikers Jiko VW MKIV-A4 TDIs (VE and PD) 4 May 31st, 2002 21:45
Where Can I get Torx Screws? Karl Roenick VW MKIV-A4 TDIs (VE and PD) 6 October 26th, 1999 11:40
Page generated in 0.11061 seconds with 11 queries
[Output: 52.04 Kb. compressed to 48.06 Kb. by saving 3.98 Kb. (7.64%)]
