Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old September 12th, 2018, 22:52   #1
BRM06
Default BRM random smoke and low oil pressure light
*2006 VW Jetta TDI BRM MK5* MODS: Kerma TDI - head, head gasket, valves, and cam. OEM: Tandem Pump, EGR, EGR Cooler, and (all sensors, other than OPS).
Fluids:
Engine Oil - 5w40 Full Synthetic (https://www.napaonline.com/en/p/COR438)
Coolant - Peak Global Extended Life
(https://www.napaonline.com/en/p/PER00243)
Personal Background: Heavy Equipment Mech specialized in diesel engines. New to VW/Cars.
I bought a 2006 jetta with the BRM engine at a low price due to malfunctions. found white smoke/ coolant leak and low power. found the low power / no boost due to a faulty turbo actuator. ( Replaced actuator. Fixed low power) ( tested coolant system and found leak via head gasket. removed head and found leak on #4 cyl. checked block deck for warpage and found none. Installed new Kerma TDI Head and head gasket with new valves and cam pre installed. (Torqued to Spec.) New radiator and heater core hoses. fixed coolant leak.) Now that engine is back together and running smoothly ( Fluid Levels are correct.) the engine will randomly start smoking out the tale pipe after being driven for about an hour then idling. ( cant tell to color of the smoke, its almost white as far as I can tell.) oil pressure light will go off randomly. ( I broke the OEM OPS when installing turbo oil supply line and replaced with NAPA branded OPS) Possibly NAPA brand OPS is bad? ( tired 2 different sensors, second has worked better than the 1st. (Have not removed oil pan to view oil pump chain.)(Also reused valve Cover Gasket that has a know leak(Plan to replace gasket)). Also plugged in a mechanical oil gauge at idle, found oil pressure to be normal at idle and during parked acceleration.
All coolant and engine oil has been replaced.
Any Ideas? any help most useful.
Additional Info after repairs: Have True VCDS cable. No CEL (Only random Oil Pressure Light) . Does NOT over heat. Does NOT leak oil.
BRM06 is offline   Reply With Quote
Old September 12th, 2018, 22:57   #2
BRM06
Timing belt, water pump, idler, and tensioner. where replaced with new head. used vw timing tools. via Kerma TDI.
Low Oil Pressure Light Slurry Pumper VW MKV-A5 Golf/Jettas 14 August 7th, 2017 04:39
Low oil pressure light. lojosh VW MKIV-A4 TDIs (VE and PD) 1 February 11th, 2017 06:44
Low oil pressure warning light CEL solved 2006 Jetta BRM 1.9 aheng Fuels & Lubricants 3 November 3rd, 2016 15:09
Low oil pressure light came one rparnel1 VW B5 Passat TDIs 24 June 30th, 2016 19:51
Low oil pressure, check engine light, glow plug light??? thomps33 VW MKV-A5 Golf/Jettas 2 March 21st, 2011 18:01
Page generated in 0.13211 seconds with 11 queries
[Output: 53.58 Kb. compressed to 49.50 Kb. by saving 4.08 Kb. (7.62%)]
