cygnus
So my alh died on the way home
Cranks great but no start.
Glow plug light so 109 relay ruled out
got fuel to the filter and fuel return to the filter with mighty vac.
Only code in vagcom is egr valve low voltage which has been that way for a while.
Asv is good valve is open.
cracked fuel lines and getting fuel to all but still wont sart.
Fuel shutoff clicks when jumped
Timing belt looks good.
The car is in town so i am trying fix away from the shop.
Im thinking my next will be cps swap and then check timing marks.
Any other suggestions?
