You can but it's a 5 + gallon tank, and gets refilled at your 10,000, 20,000 and 30,000 mile services by the dealership when they do the services that were paid for by you in the price of your car. Probably really won't have to do it yourself until your 40,000 mile oil & filter as well as fuel filter change. Get an empty container from the dealership when they do your 10,000 mile service.You can fill up the adblue youself correct? I assuming just becaue of
the refill in the trunk
TDI's are low maintenance. Drive more worry less to quote another member. I personally do not notice any sloshing.What I was thinking I was keeping it top off so It would reduce the slaushing issue that some people have reported hear inside while driving. Just a thought. Thanks.
The Adblue fill containers have a special lid. You can invert the bottle and nothing will come out. You have to place the bottle on the Adblue filler neck and press down on the bottle to release the product into the Adblue tank. At least thats how the Benz bottles work. So, it the VW filler is the same it doesn't matter what awkward angle its at,the product will only come out of the bottle when you press the bottle down. Releasing the downward pressure shuts the nozzle and keeps the Adblue from spilling out.I've got just over 4k...sloshing seems to come and go, some days, it's LOUD, others, not a sound. I'm also not sure it's always the Adblue I'm hearing, as previous gen TDIs have "sloshy" fuel tanks.
I'll bet it's not worth fussing over, risking spillage (odor? corrosion?), and inconvenience.
I've not watched one being filled, but I imagine holding a 2.5g. jug at a very odd angle while it empties is a bit awkward. (I can see that I'll line the trunk with plastic before each "service"!)
(After reading the previous line again, you might be onto something, as it WOULD be much more convenient to fill more often with a smaller container.)
Audi,BMW,MB and VW all have different part numbers for the SAME bottle. So,I assume all four manufacturers use the same filling procedure. Did they actually ''standardize'' something?Thanks, Dweisel. Now I know it's no big deal.
I don't think you can ''run it dry'' The MB gives you a countdown of remaining starts At 20 STARTS REMAINING on down. If you use up the 20 starts without refilling the Adblue you will not be able to start the engine. I'm not sure how much Adblue is left when you get to 1 start remaining.That was the next question to be answered. MB has decided that just replenishing isn't sufficient to keep it fresh? Wonder if that logic is still current, now that they've put a few million miles on their BlueTecs. Following this logic, it's probably best to run it dry (almost) before refilling, no?
I haven't checked, but I thought all the bottles were 2.5gal at the VW dealer, hence my comment about bulky/awkward. Are smaller bottles available?
I'm just going to evacuate out whatever Adblue fluid is left next week. Depending on IF I can get it all,I may rinse with some distilled water or fresh Adblue fluid and vac that out to see what if anything comes out. Then refill with fresh Adblue.I didn't mean to literally "run it dry"...I just meant to get it down within the "warning" range. Someone must know how much actual fluid is remaining at that point.
Hmmm...MB recommends (requires?) a total drain every 2 years? I wonder how difficult that is, and if VW owners should do it every time they fill, assuming it's a small amount of fluid left?
Not sure what VW charges,but at some point it may pay the 2012 Passat owners to have an Adblue top off GTG. $186 for 55 gallons. Of course you also have to pay to have it shipped.What does VW charge for the 2 litre bottles of Adblue?
I guess you've got no sense of humor...........it was a joke. On a serious note. Its always going to be cheaper to DIY than to go in for dealer service. I did read somewhere that a MB Dealership charged around $320 for a 7.2 gallon refill. Sorta pricey to say the least. AutoZone sells 2.5 gallons of Peak for $11.99...and what would the shelf life of that processed beer be?
I think we're all seriously over-dramatizing this.
LOL! Sorry,I threw you a curve with the 55 gallon Adblue GTG.You got me...I THOUGHT I had a sense of humor...
70% of it is warnings, don't spill it, don't store it in the trunk, don't this, don't that... It's corrosive.4 pages of DEF procedures. Gotta love it!
The only way that a 55 gallon drum makes sense is if you drive about 100K miles a year.You can assume that you'll get 10K miles from about 6 gallons of DEF and DEF *does* have a shelf life of two years from manufacture date.Not sure what VW charges,but at some point it may pay the 2012 Passat owners to have an Adblue top off GTG. $186 for 55 gallons. Of course you also have to pay to have it shipped.
