05TurboWagon
I just popped a code for glow plug #1. The plug tested bad; for good measure I swapped GP #1 and GP#2 as a secondary confirmation.
The plugs currently in the Jetta are Bosch 0250302002 7.0v (manufactured in 2004). I ordered a set of NGK N10591609 7.0v plugs of off IDParts last night. Did I screw the pooch or are the NGKs an acceptable replacement?
I bought this Jetta second hand. The PO did not believe the GPs had ever been changed.
It looks like this Jetta did not fall under the GP fiasco causing them to need replacement.
Am I good to go or did I flub up?
