Draderade
I'll start this off by saying that I've done my DD trying to research solutions to my issue, but it looks like most other posts are similar but not the same. Let me know if I'm missing something or you need more info please! I'm new to this site as well as VW ownership, but from what I've seen so far it looks like the community is ridiculously helpful relative to other brand enthusiast forums.
I just purchased a 2002 Jetta TDI (5spd manual) with about 438,000km on it (that's about 275,000 miles in freedom units). I know nothing about the previous owner's history, but it looks like they've taken pretty good care of it. It has a frost heater and cab heater.
The car starts and runs beautifully in warm weather, but when the temperature hits 0C (32F) it starts having cold start issues that are compounded the colder that it gets. When it hits -18C (0F), there's nearly no chance of it starting up first thing in the morning, however once the engine has warmed up it will start and run flawlessly until it sits in the cold for long periods of time.
It's currently around 20F here and after the glow plug cycle the car will crank for probably 10-15 seconds before it sputters to life. The cranking time increases exponentially and the turning-over becomes less convincing the colder that it gets. Sounds like a glow plug issue, right? I get 12.5V to each GP connector, good resistance on the GPs, actual GP timing vs dash light, and all GPs light up while plugged into the harness outside of the block. The length of the GP light on the dash is relative to the coolant temp. I unplugged the coolant temp sensor for a couple of days to test it, but no change. There is no CEL and I'm not sure what else I could test on the GP circuit. The only thing to mention is that my #4 cylinder GP is very tight going in and coming out for most rotations...
Here's the deal: It was -21C (-5F) a couple weeks back and I had the frost heater plugged in for about 2 hours before I left. The car fired up like a dream and ran beautifully. It cranked for <1/2 second and fired like a boss. I live in Saskatchewan, Canada (midwest, above North Dakota) and temperatures here in the winter fluctuate between 32F and -40F, and it's not always possible to have the vehicle plugged in...and I definitely don't want to be stranded when I can't start it warm.
Here is a quick list of maintenance items I did as soon as I purchased the vehicle because I like to have some service history:
Oil & filter change (Mann filter, John Deere 0W40 CJ-4 engine oil)
Air intake filter (Mann)
Cab filter (Mann)
Fuel filter (Mann, primed with Diesel Purge)
Transmission oil (Pennzoil Platinum 75W90 GL-4)
Thermostat & coolant (VW OEM on both items)
Glow plugs (NGK - I would have changed with Bosch if I had known they were OEM)
Battery (East Penn 694RMF)
Timing belt was done at 376,000 km (235,000 mi) by the 'stealership'
I purchased VCDS because I figured that if it could save me one trip to the shop it would be worth its weight. I also figured that if anyone on here would be able to help me troubleshoot, it would be a great tool to have on hand.
I checked the pump timing with VCDS and it's slightly above the 'average' line - a hair towards 'advanced'. I can save and post a graph if need be. I also downloaded GreenGiant's graph software and recorded the starter RPM on a cool day (28F).
I work at a Deere Construction & Forestry dealership and was able to test compression on each cylinder. I tested each cylinder going down the line twice: 575/600, 575/600, 550/550, 550/575
I feel like it's not a glow plug issue (I'm also not a seasoned veteran), but would be open to any suggestions or questions! Help please.
Cheers,
Chris
Cab filter (Mann)
Cheers,
Chris
