STI/Bremi ignition wires using the part number you gave did the trick, car is running stronger than ever. Thanks for bearing with me Oilhammer!Ignition wires in the aftermarket, much like spark plugs, are often sold incorrectly for the 2.0L engines.
The AEG uses 06A-905-409-L, the AZG, AVH, BEV use 06A-905-409-N.
I would only use OEM type (Beru is usually a good brand) wire sets, and they really can only fit one way. They come already laced in such a way as to be pretty darn impossible to put on the coil incorrectly.
