What can I check? There's no fuel in the clear line running from the filter to the IP. Any help is appreciated!
EDIT: I can not pull a vacuum from the fuel return port (with my thumb on the fuel return line to cap it off). I can blow into the fuel supply port and hear it coming out near the area with the 4 fuel delivery valves.
Does this mean I need a reseal?
EDIT: The initial 'listening' guess at air coming out at the fuel head was truly air coming out at that location. I poured soapy water over the IP, plugged the return line with my thumb and had a helper (my son) put 5psi of air into the fuel input barb. There were MAJOR bubbles at the head seal area and small bubbles at the fuel adjuster seal. Now we know what the problem is.
