Old November 7th, 2013, 16:25   #1
corzy
TDI(s): 99 jetta
Default turbo underboost
hey guys, got an engine alarm P00299 turbo-underboost
we have only owned this car for a month or so, the prior owner safetied the car 20 k before we got it, but it sat for over a year outside. not sure if this could have caused the turbo to corrode or something like that?
any suggestions.
the car is sluggish ( im used to it owning a 99 tdi with a non operational turbo, top speed is 130k, downhill, with wind )
so im not too worried, i know it will drive fine, just no get up and go, but soon i might tackle it...maybe.
i found online that you can only get this turbo with the exhaust mani, 850 from Germanautoparts...or just the vane itself for 100ish.
not sure how i could tell what the actual issue is.
thanks guys
Corzy
99 Jetta TDI <99.5 AHU
corzy is offline   Reply With Quote
Old November 7th, 2013, 16:26   #2
corzy
TDI(s): 99 jetta
sorry, forgot to say that the car is a 2003, with 220000 km. TDI obviously, and is loaded, power,leather,moonroof etc (if all that matters)(
thanks again
Corzy
Old November 8th, 2013, 22:20   #3
Monster1926
Fuel Economy: 45 mpg
Turbo actuator is rusted out its easy to change from the bottom search turbo actuator
Monster1926 is offline   Reply With Quote
Old November 9th, 2013, 03:31   #4
corzy
TDI(s): 99 jetta
how can i tell if it is rusted out or ceased, can you watch it while the cars running? do you do this from under the car?
thanks
Corzy
Old November 9th, 2013, 11:11   #5
Ridelife
the vacuum line that goes to the turbo. you take a mitivac and pull vacuum on the actuator which looks like a waste-gate (google if nessessary). there is a rod mounted to a move-able shaft. when you pull vacuum like 20 psi it should start to move (the rode that is) and go back into the actuator. i would say it moves about a inch and a half with full suction or to the stopper which you probably cant see. if it doesn't move then actuator is probably frozen.
Ridelife is offline   Reply With Quote
Old November 9th, 2013, 18:03   #6
Monster1926
Or in my case my mighty vac just kept pumping because it was rusted out. My car spent most of its life in Seattle so I'm sure snowy areas are worse
What to do w/ P0299 turbo underboost? rustybolts VW MKIV-A4 TDIs (VE and PD) 0 September 2nd, 2012 11:06
Turbo Underboost 0Silva1 VW MKV-A5 Golf/Jettas 1 September 21st, 2011 00:58
p0299 turbo underboost and smoke Mariusz257 VW MKIV-A4 TDIs (VE and PD) 9 March 9th, 2010 21:43
P0299 Turbo/super charger underboost unameiti'lltryit Ontario 5 May 3rd, 2009 16:35
Turbo Underboost kayak01 TDI 101 9 June 8th, 2008 20:06
Page generated in 0.16198 seconds with 11 queries
[Output: 71.94 Kb. compressed to 62.94 Kb. by saving 9.00 Kb. (12.51%)]
