Well I picked up a 05 tdi with 123k on it yesterday. Upon initial startup the engine ran as smooth as my 09 tdi did. Took it for a long test drive and when floored from a stop, it sounds like a wastegate is hung open for 2-3 seconds then it seals shut and sounds like a typical tdi. Any ideas where I should start looking?
The other issue sounds like the dreaded BSM rattle. Sounds great during a cold start but once at operating temperature, it is LOUD! Doesn't have the typical constant chain slop noise, it's more of a lope/surging chain slop.
Pretty sure I am going with a delete versus a gear driven set up. Timing belt/water pump was changed at 80k but I'm going to do it again while it's opened up.
