Selling My 2001 GTD
Strider17
Hamilton, Ontario, Canada
Beetle(sold) MK4 Golf TDI(sold) Mk4 Jetta TDI(parted out) MK4 Golf GTI w/ALH swap (built then parted out) 2015 Passat TDI Highline (current)
Selling my custom made 2001 GTD
6k obo
pic of the car was from 1.5 years ago
doesnt come with wheels and doesnt have the hitch installed
also the body isnt as mint anymore
all work was done by me.
literally everything was replaced
the bad:
needs windhshield
has some rust spots and paint peeling
might need a clutch soon
Well over 12k was put in the car. All parts have between 2-50k on them
reason for selling - getting a wagon
might part it out if noone takes the car complete.
it needs some TLC with the body - never been in an accident though
Car can get 1400km on 60L of fuel - (vented)
Some of the mods:
-175xxx engine -swapped
-190xxx tranny -swapped
-Malone Stage 4 Tune
-VNT17 Turbo
-Bosio 764 Nozzles
-11mm Pump
-EGR Delete
-Darkside Race Pipe
-3" TurboBack Exhaust
-PD150 Intake Manifold
-SouthBend Endurance Clutch Kit - Might need to be replaced
-Neuspeed Upper Strut Bar
-HID Headlights with Fogs
-New Engine Mounts
-Tranny Flush
-Intake Manifold Cleaned-New Gaskets
-Keyfob Window Mod - Roll Down Windows with FOB
-Both Door Lock Modules Replaced
-Radiator Replaced
-Braided Turbo Feed and Return Line
-New South Boost Gauge
-Power Memory Leather Seats
-Custom Plad Headliner and Pillars
-OEM Side Skirts
-Frost Heater 1000w
-Battery Heater Blanket
-Power Inveter
-USB/AUX Audio Hook up
-Starter Replaced
-Battery Replaced
-Center Steering Wheel Boost Gauge Pod
-Full Timing Belt Kit - 50k on it
-Serpentine Belt and Tensioner Replaced
-Alternator Pulley Replaced
-Compressor Replaced - AC Blows Cold
-All AC O-rings Replaced
-Coolant Hard Pipe Seal Replaced
-Coolant Temp Sensor Replaced
-Thermostat Replaced
-Upgraded Bigger SMIC
-2" Intercooler Piping
-InTank Lift Pump
-Glow Plugs Replaced
-Coolant Glow Plugs Replaced
-Euro Headlight Switch
-New Brake Booster Line
-New MAF
-New N75
-Short Shifter
-Custom Heavy Duty 2" Bosal Style Hitch
-Upgraded Bigger Front Brakes
-Cross Drilled Rotors with Pads
-Side Mirrors Replaced
-All Wheel Bearings Changed
-VR6 Axle Spindels for Bigger Axles
-New Rear Calipers
-Rear Neuspeed Swaybar
-Rear Air suspension
-New Rear Beam Bushings
-TT Front Control Arm Bushings
-Steering Rack Replaced
-Heater core Replaced
-All Steering Components Replaced
- Hood Plastic Bug Deflector
-Custom Outlet with Power Inverter
-R32 DashBoard
-Silver Dash Trim
- All Filters Changed
-All Fluids Changed
-Alpine Deck
-All Vacuum Changed
-JOM Coils - Have stock suspension that is in excellent shape
-3 Spoke Steering Wheel
-Stuby Antenna
-Newer Style Glove Box
-Newer Style Center Console Cupholder/Rear
-Newer Style Dash Cup Holder
-Led Interior Lights
-Monster Mats
much much more...
every seal, gasket and bolt and part was replaced
got LOTS of spare parts for it too. Everything MK4 i own will be for sale
dont have current pics of the car. needs a good wash
Strider17
parting everything out...lots of parts already sold
pm for parts/pricing
