Old January 29th, 2009, 05:00   #1
jktaylor87
TDI(s): Polo 1.4TDi
Default Polo 1.4tdi struggleing to start. HELP!
Hi guys,
My 02 Polo 1.4TDi really struggles to start when there is less than half a tank of fuel in it and it has been standing for a while.
It seems to start initially then dies instantly even when i am holding the ignition on and i cannot catch it even with my foot on the floor. Then when i turn it again the engine turns over fine but it takes about 10 seconds for it to catch with a few splutters inbetween.
Originally i thought it was a glow plug problem and put new ones in and filled the car up with diesel and the problem went away. When the tank dropped below half the problems starting returned untill i filled it up 2 days later and it stopped misbehaving!
I have not yet replaced the fuel filter but thats my next idea! Anything else you guys could think of would be appreciated!
Cheers,
P.S. I'm not getting any engine warning lights so havent bothered to test it on a VagCom (which i would have to buy!).
jktaylor87 is offline   Reply With Quote
Old January 29th, 2009, 06:17   #2
Nutsnbolts
Nutsnbolts's Avatar
Fuel Economy: Average is about 46 now (2016)
It sounds like air is getting into the fuel supply line, or that there is a restriction. I would definately go for the filter first, as this is the most likely cause...
-Rich
575,500 miles now and counting...24,500 until cluster swap! Stay tuned for engine update...
'00 Jetta GLS, '03 Jetta GL, 08 Highlander, '72 Plymouth Satellite, '68 Chrysler 300, '75 Benz 300D, 78 LeSabre Turbo.
Nutsnbolts is offline   Reply With Quote
Old January 29th, 2009, 06:50   #3
Dave_D
If you only have problems with less than half a tank of diesel I would suspect a problem with the pickup in the tank. Perhaps there is a hole in it that allows it to suck air once the fuel level is low enough.
1999.5 (A4) Tornado Red Jetta GL TDI,5 speed,4 door, RC 2+, Old Navy CCV mod, ventectomy, CAT filter
Dave_D is offline   Reply With Quote
Old January 29th, 2009, 07:09   #4
RobW2
TDI(s): 2003 Jetta
A cracked pickup line in the tank?
2003 Jetta Tdi, Ventectomy, Panzer Plate
Frost heater, OEM VW roof rack
Bypass filter, Koni FSDs, 764s
RobW2 is offline   Reply With Quote
Page generated in 0.11735 seconds with 10 queries
[Output: 58.79 Kb. compressed to 52.23 Kb. by saving 6.56 Kb. (11.17%)]
