CWill
Has anyone tuned there mk7 gsw or golf, I have looked everywhere and haven't found that much about it?? Very curious?
If you have not had the PHASE 1 fix done then you need to get it done first. The VW software fix will remove the tune.Has anyone tuned there mk7 gsw or golf, I have looked everywhere and haven't found that much about it?? Very curious?
http://forums.tdiclub.com/showthread.php?t=480681Has anyone tuned there mk7 gsw or golf, I have looked everywhere and haven't found that much about it?? Very curious?
Hi Jeff! My 09 TDI got replaced with a stop sale GSW so had to sacrifice my RC1 Eco with the car.The 2015 Tdi gsw-dsg has a horrible shift strategy and excessive turbo lag from the factory. You don't realize it until you drive a correctly tuned one. I get 5mpg's more just by being in the right gear at the right rpm/torque at tip-in with dsg tune alone (any/all gears). It gets another 3-4 mpgs (adding engine tune) by eliminating all the lag and missing low end torque. My tuned car upshifts gears between 1600-2600 (normal throttle) now instead of 1200-2200 Rpm's. The biggest improvement is keeping it out of 6th gear until 55-60 mph. When you are lugging around at 40 mph in 6th gear, and tip in to pass, it has to downshift to 4th (on same clutch pak). This factory behavior results in more lag, insufficient exhaust energy to spool turbo and belching black smoke (clogging Dpf/more regens) and fat lambda/O2 sensor correction (pulling fuel back) giving lag and soot cubed!!! I can get 100 more miles out my tank with my tuning corrections which is no big deal to me, but I can zoom around now with ease and zero lag and no more traffic drama or constantly working paddle shifters nudging gears where they belong !!! I kept Dpf, and adblue working for now, but turned off egr and intake flaps, and leaned out start up and warm up fueling. Egr is also a big contributor to throttle lag (ie. wasted energy inhibiting turbo spool). I am very impressed with the new ea288 engineering and its towing capabilities as well. It's a great prime mover, and now I gotta get the horrible suspension redone and dialed in. Btw I like the rear beam better than Irs for trailering and carrying heavy loads, along with my rear air bags.
Jeff
Yes you are right.I found the reason why MPG drops even with a little throttle input.It is post injection-1 that's ruining our MPG.You have to control your throttle precisely to dodge this post injection.I rolled back to pre-diesel gate software on 2015 Golf TDi but looks like this phenomenon is also present on pre dieselgate software.but only with VERY careful throttle pedal control. Just a little too much, and the mpg drops into low 30's instantly. Into the twenties if you accelerate up a hill, even a little. Just stupid!
Thanks for chiming in KERMA.Yes i took that screenshot just after the regen to show the phenomenon but it happens all the time even with a little throttle input.I can confidently say all the time even when the engine is fully warmed up.By All the time i mean whenever you give 3-4% throttle.If you give very little then it doesn't turn on and also it doesnt turn on under heavy acceleration.Here is another screenshot.you are actually in regen in that screenshot
observe the km since last regen. (1 km)
the post dpf temp higher than pre dpf temp indicates nox/sox regen (depending on the model of car of course)
You will also see some post injection from time to time to keep the oxicat at operating temp, for instance during a long downhill stretch. Also during warmup to get the oxicat lit off.
