martin33100
Hi guys, just wondered what is classed as sensible back pressure over a DPF/exhaust etc? before you start to limit performance.
The car in question is our BMW X5 3.0d, when you are at WOT the pressure before the DPF peaks at around 480mbar.
When I do the DPF back pressure test with the just the engine running and no driving I have approx 12mbar at idle, 55mbar at 2000rpm and 100mbar at 4000rpm, these results are roughly half the BMW max recommended value.
Any advice on a driving under load exhaust back pressure would be great.
