99.5 2.0 Golf Build
bgsnyder
Cedar Rapids, IA
99.5 Golf & 2005 Passat
Any idea how the back cover could have broke? Once the tensioner is tightened it shouldn't be able to move, even without the notch in the rear cover, right?
JFettig
Blaine, MN
B5 Passat, 2010 Jetta
You're correct, the back cover should not have broken - nor should that have been the cause of the failure if it was originally tensioned correctly.
Where is the tab now? Where it should be or somewhere else?
bgsnyder
Cedar Rapids, IA
Well I checked the nut on the tensioner and it was still tight. So I'm even more stumped at what broke that cover. It seems like the belt was rubbing on something until it stretched enough to hop teeth.
ATR
Baltimore
2011 Golf TDI 6MT
I'm very curious to see what may have caused this to happen. Did it skip timing enough to damage the engine?
bgsnyder
Cedar Rapids, IA
After a year of sitting I finally decided to check and see what happened. Looks like the bolt holding the lower idler broke. :(
bbarbulo
Windsor, ON, Canada
absolutely heart-breaking!! all that great work and gets spoiled by stupid design. really, what engineer in his right mind says yes... let us carry a dynamic load through a bolt that is TTY and also removed with relative frequency. The block should have a spindle cast into it that carries the load, and a bolt should only hold the bearing tight to the spindle. The same way the engine shouldn't hang off bolts either, esp not bolts threaded into aluminum.
I hope your engine is ok and you can get the car back together, actually enjoy it a little while.
