2000 Jetta TDI ac hasn’t been working right for awhile.Did the blend doors since foam has been coming out the vents for 2 years.Sometimes it cooled somewhat and other times not at all.Fans are on and clutch engaged.I tried RCV valve and noticed the old one had a blackish film and some small metal bits,not a lot but enough to be noticed.I put it together and vac system which held for an hour.I recharged and vent temp went to 34degrees.Turned all off and after unhooking gauges and turned on and air got less cool.Now air is warm.I believe my compressor is bad and there seems to be so many choices.Any recommended brands that are reliable.I think I need comp,Evac valve ,drier and condenser to do it right.Also when I took comp apart no oil was present.If the system never appeared to leak can the oil dry up over time causing problems.Pressures were around 30 low and high never went above 100 on an 80 degree humid day.Any ideas would be appreciated.
