Old September 15th, 2016, 11:20   #1
wulferus
Default ASR light on after 5 speed swap b5 passat
I just picked up VCDS, and have never used it before, so bare with me.... I was told by user vwzips that given my situation, and with Bosch 5.7 abs, I need to:
"log in, change the soft coding and reset the CanBus (don't forget to unplug the TCU!)"
I was hoping someone could explain that a little more to this noob. I didn't want to revive the bit off topic thread in the wrong forum, but here's a link for the interested:
http://forums.tdiclub.com/showthread.php?t=464723
May provide more insight.... Cheers folks!
wulferus is offline   Reply With Quote
Old September 15th, 2016, 12:21   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Ross-tech has everything on their wiki website.
You'll need to generate a log in number based on the car's equipment, then input that login number, then change the soft coding... again based on the car's equipment. If the car just has ASR, and no ESP, then you won't have to do a recalibration of the steering angle sensor, since it won't have one.
oilhammer
www.cardocautomotive.com
Old September 22nd, 2016, 20:54   #3
wulferus
Thanks oil hammer. I did there process described on the Wiki and their YouTube video. However, despite researching, I can't figure out how to reset the canbus
Old September 22nd, 2016, 21:53   #4
Matt-98AHU
Matt-98AHU's Avatar
Goto the coding in the CAN Gateway and leave the number at 0006 or whatever the default is, then click Do It!
Basically, whatever is connected to the CAN Bus at that time will be the new "installed controller" list.
Sole Proprietor, Diesel Autowerks in San Anselmo, CA. One man operation, email is preferred method of contact: email me with inquiries for service.
Matt-98AHU is online now   Reply With Quote
Old September 23rd, 2016, 03:40   #5
oilhammer
oilhammer's Avatar
Oh yeah sorry, I didn't get the second part of your question about the CAN, just the first part about the ABS.
oilhammer
Old September 23rd, 2016, 11:42   #6
wulferus
And I disconnect my TCU before doing this? Manually I presume?
Old October 2nd, 2016, 07:27   #7
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
Yes , need to disconnected TCU and leave it that way.
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
B5.5 Passat 6 speed manual trans swap Sprocket VW B5 Passat TDIs 106 April 5th, 2018 12:31
b5.5 passat five speed swap B5.5 passat VW B5 Passat TDIs 5 February 1st, 2016 07:06
My Passat b5.5 6 speed swap krdmachinefabrication TDI Conversions 0 June 29th, 2014 10:16
B5.5 TDI Wagon 5-speed swap - CoolairVW review blujett2.0 VW B5 Passat TDIs 19 June 24th, 2014 10:10
2001 B5.5 Wagon with TDI/5-SPEED swap If to buy. dugwerks VW B5 Passat TDIs 6 September 30th, 2012 13:46
Page generated in 0.17206 seconds with 11 queries
[Output: 81.22 Kb. compressed to 70.40 Kb. by saving 10.82 Kb. (13.32%)]
