Basic facts:
2001 Jetta TDI 280K mi
Auto trans - went into limp mode.
Error code (p0722) -indicates no signal. Per review of here and others indicates g68 sensor error either the sensor itself or wiring.
I removed airbox and battery box - removed the tranny mount, lowered the tranny and have access to the G68 sensor. Had Major pain in the butt disconnecting the electrical connector - anybody got an easier way to remove these connectors? I end up breaking them about half the time...
What I did see is that where the pigtail ran from the sensor to the connector it went under a retaining clip which rubbed the insulation and shielding off of the wires and I assume grounded out the signal.
So now I'm trying to remove the sensor itself. I've removed the 10mm bolt holding it in and the sensor rotates around the hole but does not seem to want to come out. Any words of wisdom on how to get it out?
Thanks in advance,
Tim
Thanks in advance,
Tim
