Lefty
CEL Scan Code P3130 OBD
Check engine light came on today. I read some posts here about it and read in the TDI FAQ under troubleshooting. I do have a air line coming out of the EGR that has been getting worn out. The clamp is missing that holds it and I try to keep it on top of the Engine Cover but the last time I changed the oil I forgot to put it on top and now it is really worn down. Can't tell if it has a hole in it or not, but suspect it does and that is what caused the CEL to come on. I am going to check the line better in the morning and replace it. Is that the 5/32 size or does it have to be the 3.5 mm? Don't know much about MM and neither does my local Auto parts guys most likely.
The P3130 Code says Fuel Air Metering and Aux Control. Are these related to the EGR? Any other ideas are welcome. Thanks for any help.
