detroitdiesel
Hello, was wondering where you guys think i could buy one of these, either genuine holset or Chinese clone. Thanks!
Look for a member called Alcaid on vwdiesel.net.
I'm here as wellLook for a member called Alcaid on vwdiesel.net.
Either that or use that 2052 as a HP turbo in a compound setup, the comp map is perfect to run high efficiency low boost so perfect in a compound, not so much as a maxed out single turbo as it really isn't a good high boost turbo and it runs out of compressor flow a bit earlyHe has been trying to get me to try one in place of my 2052 setup.
