Lightflyer1
This is your initial scan and after clearing codes and seatbelt chime removed appended to it.
Sunday,04,December,2011,11:53:56:44380
VCDS Version: Release 11.11.0 (x64)
Data version: 20111111
Chassis Type: 9M - VW Jetta IV
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: 3VWRR69M04M065243 Mileage: 248430km/154367miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 038 997 016 L HW: 028 101 114 6
Component: R4 1,9L EDC G000AG 3791
Revision: 12345678 Serial number: VWZ7Z0C8182086
Coding: 0150034
Shop #: WSC 25161 444 54746
VCID: 2756397595F60B6
3 Faults Found:
18996 - Turbocharger Boost Control Position Sensor Circuit
P2564 - 000 - Signal too Low
Freeze Frame:
RPM: 882 /min
Torque: 32.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Lambda: 6.4 %
Absolute Pres.: 1030.2 mbar
Absolute Pres.: 999.6 mbar
18058 - Powertrain Data Bus
P1650 - 000 - Missing Message from Instrument Cluster
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.40 V
Bin. Bits: 00001100
Torque: 0.0 Nm
Torque: 110.0 Nm
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 00001100
Bin. Bits: 00000000
(no units): 0.0
Readiness: 1 1 0 0 1
Address 02: Auto Trans Labels: 09A-927-750.lbl
Part No: 09A 927 750 AM
Component: AG5 Getriebe 09A 0242
VCID: 76E8243152DC22E
1 Fault Found:
00300 - Transmission Fluid Temp. Sensor (G93)
27-10 - Implausible Signal - Intermittent
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00066 000 00000
VCID: 336EDD25512E776
2 Faults Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
003 - Mechanical Failure - Intermittent
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
Part No: 1C0 909 605 F
Component: 04 AIRBAG VW61 0202 0003
Coding: 12340
Shop #: WSC 00066
VCID: 27563975C5F60B6
2 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
49-10 - No Communications - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J5 920 906 R
Component: KOMBI+WEGFAHRSP VDO V53
Coding: 15234
Shop #: WSC 00050
VCID: 3C7CF6192C70B8E
3VWRR69M04M065243 VWZ7Z0C8182086
8 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
01128 - Immobilizer Pickup Coil (D2)
35-10 - - - Intermittent
01176 - Key
01314 - Engine Control Module
01316 - ABS Control Module
01321 - Control Module for Airbags (J234)
01315 - Transmission Control Module
01336 - Data Bus for Comfort System
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00066
VCID: F0E49229B0B88CE
5 Faults Found:
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00066
VCID: 3776E93515569B6
Subsystem 1 - Part No: 1C1959801A
Component: 1H Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802A
Component: 1H Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811A
Component: 1H Tõrsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812A
Component: 1H Tõrsteuer.HR KLO 0202
7 Faults Found:
00932 - Electric Window Motor; Drivers Side (V147)
62-10 - No or Incorrect Adjustment - Intermittent
01331 - Door Control Module; Driver Side (J386)
37-00 - Faulty
01332 - Door Control Module; Passenger Side (J387)
37-00 - Faulty
01333 - Door Control Module; Rear Left (J388)
37-00 - Faulty
00935 - Electric Window Motor; Rear Right (V27)
01334 - Door Control Module; Rear Right (J389)
37-00 - Faulty
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 F
Component: RADIO 3CP 0005
Coding: 00401
Shop #: WSC 00066
VCID: 234E2D65B1CEE76
No fault code found.
End ---------------------------------------------------------------------
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 15: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 46: DTCs cleared
Address 56: DTCs cleared
75 76
Coding: 0150034
1 Fault Found:
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Lambda: 6.4 %
Absolute Pres.: 183.6 mbar
Absolute Pres.: 958.8 mbar
Readiness: 0 0 1 1 1
Coding: 0004097
Coding: 12340
Shop #: WSC 00066
Coding: 15234
Shop #: WSC 00050
Coding: 00006
Shop #: WSC 00066
Coding: 00258
Shop #: WSC 00066
Coding: 00401
Shop #: WSC 00066
Address 17:1J5 920 906 R recoded (Short coding) from 15234 to 05234 (00050/---/-----)
75 76
Coding: 0150034
3 Faults Found:
Freeze Frame:
RPM: 882 /min
Torque: 32.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Lambda: 6.4 %
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.40 V
Bin. Bits: 00001100
Torque: 0.0 Nm
Torque: 110.0 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 00001100
Bin. Bits: 00000000
(no units): 0.0
1 Fault Found:
Coding: 0004097
2 Faults Found:
Coding: 12340
Shop #: WSC 00066
2 Faults Found:
Coding: 15234
Shop #: WSC 00050
8 Faults Found:
01176 - Key
Coding: 00006
Shop #: WSC 00066
5 Faults Found:
Coding: 00258
Shop #: WSC 00066
7 Faults Found:
37-00 - Faulty
37-00 - Faulty
37-00 - Faulty
37-00 - Faulty
Coding: 00401
Shop #: WSC 00066
75 76
Coding: 0150034
1 Fault Found:
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Lambda: 6.4 %
Coding: 0004097
Coding: 12340
Shop #: WSC 00066
Coding: 15234
Shop #: WSC 00050
Coding: 00006
Shop #: WSC 00066
Coding: 00258
Shop #: WSC 00066
Coding: 00401
Shop #: WSC 00066
