Tuesday,26,April,2011,13:33:46:46862
VCDS Version: Beta 912.0
Data version: 20091201
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Mileage: 232330km/144363miles
Address 01: Engine Labels: Redir Fail!
Part No: 038 906 018 P
Component: 1,9l R4 EDC 00AG 1623
Coding: 00001
Shop #: WSC 05314
4 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
00575 - Intake Manifold Pressure
17-10 - Control Difference - Intermittent
01266 - Glow Plug Relay (J52)
31-10 - Open or Short to Ground - Intermittent
00626 - Glow Plug Indicator Light (K29)
Readiness: N/A
Address 02: Auto Trans Labels: None
Part No: 01N 927 733 CN
Component: AG4 Getriebe 01N 3815
Coding: 00000
Shop #: WSC 00000
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl
Part No: 8E0 614 111 AM
Component: ABS 5.3 FRONT D30
Shop #: BB 24548
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 604 A
Component: AIRBAG VW3 - V04
Coding: 00065
Shop #: WSC 05311
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 3B0-919-xxx-17.lbl
Part No: 3B0 919 931 A
Component: B5-KOMBIINSTR. VDO V34
Coding: 04440
Shop #: WSC 00000
Part No: IMMO
Component: IDENTNR: VWZ7Z0W0560031
IMMO-IDENTNR: VWZ7Z0W0560031
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 G
Component: 0D Zentral-SG Komf.0002
Coding: 00257
Shop #: WSC 05311
Part No: 1J2959802D
Component: 0D Tõrsteuerger. FS0001
Part No: 1J2959801E
Component: 0D Tõrsteuerger. BF0001
4 Faults Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
01358 - Internal Central Locking Switch; Driver Side (E150)
27-10 - Implausible Signal - Intermittent
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
27-00 - Implausible Signal
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
End ---------------------------------------------------------------------
i remembered how to do it now 'so what do you think guys ??
