Old March 7th, 2010, 00:43   #1
andrew1984
TDI(s): several!!
Default Wiring; converting dual stage fan to single stage
Wiring; converting dual stage fan to single stage.
I have the ALH in my rabbit now and am running a Scirocco rad with a dual electric fan w/shroud. The fans are single stage. Which wires should I hook up as I am running complete 98 beetle wiring and fan control box.
Assuming this is possible.. Could I just run the high fan speed for each stage? If so, which wire would I want, the thicker one?
Cheers
Andrew .Volkswagen. Cordeiro .:R
Andrew@MakeHasteRacing.com
www.makehasteracing.com Twitter @MakeHasteRacing
1975 Scirocco ALH TDI, 1982 Rabbit Pickup ALH TDI
2008-2010 Volkswagen Jetta TDI Cup #26
andrew1984 is offline   Reply With Quote
Old March 7th, 2010, 09:27   #2
MrDave
One fan speed has a resistor in-line (internal to the fan).
You could just play with it, with 12V and ground, see which one is faster.
For my swap, I didn't use the mk4 fan control circuit.
I used a mk2 dual temp fan switch and a mk2 dual speed fan.
Very simple to wire up, 12V and ground.
-Dave
MrDave is offline   Reply With Quote
Old March 7th, 2010, 20:53   #3
andrew1984
TDI(s): several!!
thanks dave!
Page generated in 0.09792 seconds with 10 queries
[Output: 53.18 Kb. compressed to 47.95 Kb. by saving 5.23 Kb. (9.84%)]
