Lex4TDI4Life
Looks like I will be logging at least 1700 miles in one week. doing an oil change beforehand and will be bringing a small toolkit, coolant and oil. wish me luck!
Lex4TDI4Life, GOOD LUCK and safe voyage on the drive.!Brasil said:What are some of the tools you all carry?
Brian: Wow! You must have been a Boy Scout when you were younger....BrianCT said:Lex4TDI4Life, GOOD LUCK and safe voyage on the drive.!
Brasil,
I have almost every kind of tool imaginable. I keep it all in a rather compact case bought from Home Depot.
Full Philips and Flat Head screw drivers
Metric wrench set sizes from 05 - 33 open and closed ends
Stanley tool set, metric and standard rachet 102 pc set
All Torx Handle size set from 04-30
Oil Filtre wrench
Serp Belt
Battery operated soldier gun w/soldier
Electrical wiring,
fuses all types,
Male/Female quick connects
every bulb at least one for an emergency replacement
Duct tape, three size widths
Open end adjustable wrenchs 1" to 3"
Vise Grips various needle to wide and clamp styles
Metal files, various sizes
Wire Bushes, various styles
Sand paper, various grades
Brake tool Metalnerd
Brake lubricant
Copper Anti-Seize Jar
Pad Lubricant anti squeal
Grease - tube high heat
Fuel Filtre, air filtre
Stanadyne 32 oz
Magnetic extendable handle to retrieve dropped objects
Standard hammer
Rubber hammer
Mini Crowbar
Breaker bar in extended version lengths
Oil plug and washer 2 sets
Here I'm able to have the door locks serviced
I have in the centre compartment a full Torque Wrench Set
This small craftsmen set fits on top of the torque wrench set in the middle compartment of the tool sack
I use a knee cushion which is stored to the rear of the sack in the compartment [trunk]
LOLaja8888 said:Brian: Wow! You must have been a Boy Scout when you were younger....
"Be Prepared.
Don't be easy on the rpms and use the least amount of steady throttle cruising as possible ..i.e. no cruise control.sasouza76 said:Myself, Wife and 2 Chihuahuas are making a trip from AZ. to NO. CA. tomorrow 22nd for Xmas week. 2009 Jetta/SW TDI with only 1100 miles on it. Will update on my adventure and milage.
Brazil: even though I was a Boy Scout once upon a time, I am not nearly as prepared as Brian. On my trips, I generally take a cell phone, credit card, $20 in cash, my laptop, a 12 pack of Diet Pepsi, and my sunglasses. Oh, forgot my Power Service and a spray bottle of window cleaner...Brasil said:AJ-- I'm not worthy! That's more complete than my home tools--maybe that's why I never made Eagle
BrianCT-- in my line I should carry a foldout couch, a cigar, and maybe some alprazolam
The foldout couch is nice. The cigar means you have time. But a schedule IV drug just put this post as being priceless. LOLBrasil said:BrianCT-- in my line I should carry a foldout couch, a cigar, and maybe some alprazolam
Brian: pretty soon you are going to need a trailer..BrianCT said:The foldout couch is nice. The cigar means you have time. But a schedule IV drug just put this post as being priceless. LOL
You have to understand how that tool kit became what it is today. When you talk friends into buying TDi's you can expect that the fear of dealerships grows quickly after visiting this site. So I'm always offering a free hand on standard maintenances... which has grown to brake jobs and... alot of other stuff too. I started off with a small little tackle box in 2002.
Lex4TDI4Life said:1st leg complete:
694 miles
50.8 mpg
61 mph average
Didn't stop to take a break until 8 hours in
8 hours??? Do you have a passing acquaintence with Mr. Foley?Lex4TDI4Life said:Didn't stop to take a break until 8 hours in
paramedick said:8 hours??? Do you have a passing acquaintence with Mr. Foley?
Was it you that I met outside Starbucks on Boston Post Rd in Darien last month?Lex4TDI4Life said:Last leg: Chicago to Stamford, CT
885 miles
69 mph average
41.8 mpg
I wasnt eager to spend too much time on I-80, so I kept the speed up around 85-90 for much of the trip.
Total trip data:
2190 miles
47.057 gallons of fuel
46.54 mpg
Not too bad for winter fuel, snow tires and some excessive speeding
