libbybapa
- Joined
- Nov 15, 2011
- Location
- Where?
- TDI
- '83 AHU mTDI high top Vanagon, '84 AHU mTDI pop top Vanagon, '85 Franken-mTDI Adventurewagen Vanagon, '91 Vanagon ALH mTDI tin top auto, '02 Jetta eTDI Wagon, '02 Jetta eTDI Sedan
On one of my '02 Jetta wagons I'm having an issue with one of the key fobs. The fob worked fine for a couple years. Recently the range has gotten terrible. The keyless entry works for all the buttons of the fob but you need to have the fob near within a couple feet of the instrument cluster area. It will not work from the passenger or rear sides of the vehicle. Oddly enough I have two other fobs for that car and they will work from 20+ feet away so it is an issue specific to the fob, not the car. I've tried replacing the battery with a couple new ones with no improvement. I've also even tried swapping batteries with one of the fobs that works from 20' away and the problem stayed with the fob so the issue is not the battery. I've opened up the fob and made sure the little metal tabs are contacting the battery properly. Anyone know what about the fob functions to transmit the signal? Any suggestions?
