pgde
Hi All:
Several weeks ago, my TPMS light came on and started to blink. This means one or more of the sensors has malfunctioned. So I took it to Costco and they replaced the sensor successfully. A week later the light came back on. Returned to Costco and they said a second sensor had malfunctioned. Based on some research I have done on this issue, the sensors have a life span of between 9-10 years. So, I told them to replace all the other sensors. Since that time, my TPMS light has been on, even though pressures are correct. Since I have VAGCOM, I followed to the detail, the "relearning" procedures posted on their site. No luck. According to Costco, for some reason the Jetta is not recognizing the new ones. Based on their meter, all are broadcasting fine.
So, before I go back to Costco and argue about a refund, does anybody have any suggestions? Where is the TPMS reception point on the car? And, here is a cut and paste from the VAGCOM log:
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Part No SW: 1K0 959 433 CD HW: 1K0 959 433 CD
Component: RDK 0420
Revision: 00051000 Serial number: 00000000000000
Coding: 0100101
Shop #: WSC 00066 000 00000
VCID: 74EC5B7A17D4B5E1F7-8020
1 Fault Found:
01521 - Sensor for Tire Pressure
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 7
Reset counter: 137
Mileage: 130516 km
Time Indication: 0
Date: 2000.00.00
Time: 09:54:50
Many thanks for any help or insight you can provide!
Peter
Component: RDK 0420
Coding: 0100101
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 137
Mileage: 130516 km
Time Indication: 0
Date: 2000.00.00
Time: 09:54:50
Peter
