Looking forward to hearing about your experience!ordered one today. will post details later.
Sorry for this late response...........The Turbo is a significant source of the oil that ends up in the charge pipe to the Inter Cooler on to the EGR system and Intake Manifold!
How do you know this? Have you tried to separate the two the way the OP has with an isolated CCV first and monitor what then goes to the IC (assumed from the turbo)? Just looking for quantifiable experience. He said it was "clean and dry" when he later checked it and the IC drain stopped producing oil. I am wondering if residual oil once it finally was cleared/removed in the IC did not continue to accumulate with just the CCV separator installed?
1. Those knowledgeable of Turbos will tell you that their seals do not seal 100%. In fact, the two seals (exhaust side and intake side) are nothing more than metal expansion rings with a gap (no rubber seals). However, exhaust pressure helps reduce oil loss on that side. And, likewise, air pressure helps reduce oil loss on that side of the turbo. So, from idling to high RPMs (throughout the range) some oil will go by the seals. These engines have over 70 psi oil pressure at idle with cold oil. At 60 to 70 MPH, with RPMs at 2000 to 2300, oil pressure is in the high 30s psi to low 40s psi with engine at full operating temp. Thus, the Turbo air pressure is far less than oil pressure ............. now go figure.
2. I have an E-vac Scavenger system on the ALH engine in my Vanagon which pulls crankcase blow by fumes/oil vapor into the exhaust system. So, with that system, 100% of all blow-by fumes/oil vapor does not go through the Intake System. But, via the turbo, my Intake System still shows oil, which based on the above rationale, comes from the Turbo. The engine runs awesomely great at 174k miles. It takes about 1/2 quart of oil to keep it full between 10k mile oil changes. Also, the ALH engine in the Vanagon has a mild Stage 1 Malone tune. I only had to add 1 quart of oil pulling a camper almost 11k miles to Alaska and back last summer (2014).
Lastly, I've done a lot of MKIV TB changes and yet to find a "DRY" Intake system. Unless the Turbo is removed and trash canned and the CCV system re-routed, there will always be oil in the Intake System.
So, I stand by my statement......
Below, in the pic you can see the stainless braid hose that connects to the E-vac Scavenger (post CAT pic below).
Below, CAT on the right and glaspack muffler to the left (exhaust flow is from right to left).
Below, looking up stream in the exhaust system..
I've been running the E-vac Scavenger over 44k miles with no issues at all. But, as stated above, the Turbo does dump some oil into the Intake System..............
I kinda did along time ago. I don't remember where I got the info, but it said you need a check valve in the line going back to the crankcase. I installed it with a tee in my dipstick, but don't do that. The drain needs to go below the oil level. I haven't found anything to explain why, but that's what it said.Why not plumb that back to the pan and make it maintenance free?
Andy: I guess this answers my question. It sounds like you are still getting oil in the IC and the only source I can think of would be the turbo seals. It looks as though a drain at the bottom of the IC is still needed. I don't see any other reasonable way to isolate the turbo oil source and it seems to still be an issue. Thanks passing this along so we all can benefit from your experience.
Chris: I for one did not realize this and am glad you posted it. I thought it was just a labyrinth and drain back for the oil (Anyone got any pics of one opened up?). If/when I deal with this I will strongly consider leaving the hockey puck in place and add whatever I do down stream from there. As you say, if you are up on your maintenance it shouldn't be an issue but I still think leaving it there is a REALLY good idea....say a snow drift across the intake, etc. It can happen in just a few minutes!You realize that the OE hockey puck is actually a pressure regulator, right?
It has a spring-loaded diaphram inside that prevents a runaway in the event of a severe restriction in the intake tract upstream of the CCV entry point. Since this is such an unlikely possibility (i.e., a plugged air filter/snow screen), it shouldn't be a problem to eliminate it since you're on top of air filter/snow screen maintenance, but I just wanted to make sure you understood the issue.
i thought the same thing, until i busted it open......it was just a labyrinth and drain back for the oil (Anyone got any pics of one opened up?). If/when I deal with this I will strongly consider leaving the hockey puck in place and add whatever I do down stream from there.....
From post #129
that seems to be the answer............
Andy: ....sounds like you are still getting oil in the IC and the only source I can think of would be the turbo seals. It looks as though a drain at the bottom of the IC is still needed.......
would have been nice to see this 2 weeks ago i would of saved $20.00. guess i didn't look good enough.Here’s a link to the BMW oil seperator.... for $10.97 and FREE SHIPPING.....http://www.ebay.com/itm/New-BMW-E53-X5-Oil-Separator-11151705237-/281577540268?hash=item418f544aac&vxp=mtr
you are correct. puck will take some trying. do you tap above diaphragm, or below? i don't know. post 131 was before i had the IC tapped.Thanks for the pics and the efforts guys, pretty clear now.
Quote: "if you do as posted, there will be no way to use the puck."
DeeJaaa: In post 131 you left the puck in place and added the cyclone separator. Is there a reason you then removed the puck other than needing to tap into the ell in the valve cover for the IC line? I was think of running the IC line into a tee in the line between the puck and cyclone, and keeping the puck for the runaway issue.
The reason you never "struck" oil when you drilled into the Inter Cooler is because you were drilling in the wrong location. In the oil well drilling business, they'd call that a dry hole.surprisingly no oil came out.
for the 45
Correct, with this arrangement the crankcase will be pressurized under boost and you will loose some boost pressure out the separator drain. Its a bridge too far. No need for a shutoff valve, just lose this part of your system.Also, if I understand your set-up, it appears there is a "constant" flow of boost pressure going thru and over to the separator from the Inter Cooler nipple fitting where you drilled the hole. And, sure, considering there is a constant air flow some oil will end up in the catch can. Further, your set-up is adding to the blow-by pressure in the CCV system.
The set-up needs a solenoid operated shut-off/on valve which can be periodically operated.
I was think of just putting a tee in the hose that goes between the puck and the cyclone and no taping into the puck? I guess taping it in anywhere in that hose, the cyclone separator, or the collection jar would be ok?puck will take some trying. do you tap above diaphragm, or below? i don't know.
I'm a little uncertain as to what you are trying to communicate. But, I'll say this:Correct, with this arrangement the crankcase will be pressurized under boost and you will loose some boost pressure out the separator drain. Its a bridge too far. No need for a shutoff valve, just lose this part of your system.
Also note how short and direct the OE CCV path is, how close the elbow hose runs to the valve cover, and the fact that the entire tract is covered by the top shroud. That's all intentional; it preserves the heat of the blowby gasses which minimizes the chance of icing of the water vapor in the gasses with resultant plugging of the system in really cold climates. Even with those design elements, a CCV heater was still specified. Your long, distant CCV path will allow the gasses to run cooler. This obviously won't be a problem in Baytown, but keep it in mind if traveling way up North.
Lose the IC recycle circuit, keep everything else (including your valve cover elbow, if you want), and you'll be golden.
It interesting to note that companies that make the best aftermarket fully-engineered CCV filter systems (Mann Provent and Racor) have not attempted to tackle a dedicated intake tract filter system let alone a combined CCV/intake tract filter system.I'm a little uncertain as to what you are trying to communicate. But, I'll say this:
1. The whole idea of a CCV is to relieve crankcase pressure, not increase it.
I think we're saying pretty much the same thing; you said "Further, your set-up is adding to the blow-by pressure in the CCV system". True and since boost pressure is greater than blowby pressure at the valve cover fitting, boost pressure is also re-entering the valve cover through the fitting, thus pressurizing the crankcase, as well as the CCV system downstream of the fitting.
2. The intent of the separator is to reduce the amount of oil in the Turbo charge path to the Inter Cooler and on to the EGR/Intake/Cylinder head. In this case, that was the intent but the intent of a CCV separator or filter in every production and aftermarket turbo application that I'm aware of is to coalesce oil in the blowby gasses only, not the intake tract. The connection between intake tract and crankcase (via the CCV) should only occur upstream of the turbo, never downstream of it. Why? Because of Point #1.
3. So, why not install the drain access in the lowest point of the Inter Cooler? Yes.
4. The oil accumulation in the bottom of the Inter Cooler would only need to be purged periodically, not constantly. Yes, purged manually with a drain plug.
5. Icing of the system would be the least of my worries, although the OE system is designed to deal with that. Agreed.
So, in reference to the hole drilled in the Inter Cooler ............. it is in the wrong place. There will still be oil accumulation in the bottom of the IC whether it comes from the CCV or the Turbo bearings. Thus, as set-up, I see very little benefit.
As you may have seen in my E-vac System (Post #129), there is a vacuum created on the CCV puck, with no back pressure. Of course, that system is extremely easy to set-up with the ALH engine in a Vanagon. It would not be an easy installation in a car. The E-vac unit would have to be located post muffler to avoid back-pressure......... been there and dealt with it. A properly installed E-vac system will generate "vacuum" under all conditions. And, it is not an experimental concept as it has been in use with race engines for years.
Point is:
1. No add-on system should increase pressure in the crankcase (the seals won't like it, and the clutch will let you know when it gets oiled from a blown crankshaft seal)
2. No system should leave oil in the bottom of the Inter Cooler if the intent was to remove it.
3. As I have proven, and is a well known phenomenon, oil gets into the charge system from two sources, the CCV system and the oil seal on the Impeller side of the Turbo.
So, why design an add-on system that adds crankcase pressure and does not eliminate/reduce oil from the Turbo seal source when that was the intent.
Otherwise, I like what I've seen and give thanks to Josh8loop for starting this Thread and sharing his ideas and experiences as well as all who have contributed.
i had a hard time trying to figure why you said it was pressurizing the crank case. i read Chris Bell's comment and i snapped into reality...... The whole idea of a CCV is to relieve crankcase pressure, not increase it.
.......So, in reference to the hole drilled in the Inter Cooler ............. it is in the wrong place. There will still be oil accumulation in the bottom of the IC whether it comes from the CCV or the Turbo bearings. Thus, as set-up, I see very little benefit..........The E-vac unit would have to be located post muffler to avoid back-pressure......... been there and dealt with it. A properly installed E-vac system will generate "vacuum" under all conditions. And, it is not an experimental concept as it has been in use with race engines for years.......
