Old February 27th, 2013, 15:31   #1
Trimmy
Default Which VCDS
I am thinking about purchasing a VCDS soon. I see on there sight they offer a $250 a $350 versions and a couple triple that. I just want to have a VCDS for whatever I would need to use it for on my car. Whats the benefit of the 350 one over the 250?
Soon to come Trimbach's Diesel Performance (TDP)
Mine: Grey 2000 Golf TDI, 04 Duramax TDP tuning
Wifes: Grey 2010 Jetta TDI DSG, Totally Stock.
Have VCDS USB HEX-CAN and VE and CR Timing Belt tools in Dayton, Oh, Willing to perform any services needed.
Trimmy is offline   Reply With Quote
Old February 27th, 2013, 17:01   #2
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
$250 = CAN Bus only
$350 = Dual K and CAN Bus
Basically if you're going to scan 2005+ cars ONLY, get the $250. If you have older cars, you need the $350.
I have the old Dual K only, someday I'll upgrade.
1994 Jetta 1.8 2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TFSI 4Motion, 2014 Jetta 2.0
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Old February 27th, 2013, 17:46   #3
JSWTDI09
JSWTDI09's Avatar
Originally Posted by NB_TDi View Post
$250 = CAN Bus only
Minor correction:
$250 Can bus only (microCAN)
$250 Dual K only (KII-USB)
$350 Dual K and CAN bus (HEX+CAN)
#1 for newer VWs only
#2 for older VWs only
#3 For both older and newer VWs
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old February 27th, 2013, 19:58   #4
Trimmy
I only plan on my 03 so the KII-USB will do everything I need?
Old February 27th, 2013, 23:22   #5
JSWTDI09
JSWTDI09's Avatar
Yes.
Have Fun!
Don
MK5/MK6 VCDS lite vs VCDS Full?? storx TDI Power Enhancements 3 July 30th, 2012 12:15
Need help with VCDS heartlandcycle OBD Scanners 1 September 12th, 2011 16:32
VCDS or Not to VCDS, THAT IS THE QUESTION BRADFORDKO TDI 101 6 July 15th, 2011 22:21
vcds wkobe VW MKIV-A4 TDIs (VE and PD) 1 March 26th, 2011 13:28
Anyone with VCDS available? hobojoker Eastern USA 0 July 17th, 2010 15:32
Page generated in 0.15453 seconds with 11 queries
[Output: 70.01 Kb. compressed to 61.78 Kb. by saving 8.23 Kb. (11.76%)]
