Old July 30th, 2012, 11:05   #1
storx
Default MK5/MK6 VCDS lite vs VCDS Full??
I need to order a new VCDS as the person i have always barrowed from is moving away soon.. Which would be more benfit for a Big Turbo build on a 2009?
Da Diesel Build
storx is offline   Reply With Quote
Old July 30th, 2012, 11:22   #2
JFettig
JFettig's Avatar
wrong forum dood.
Minnesota Malone Tuning dealer
1998 B5 Passat TDI Compound Turbos
2009 JSW Stage 3 196whp so far
DIY injector calibration http://forums.tdiclub.com/showthread.php?t=383324
JFettig is online now   Reply With Quote
Old July 30th, 2012, 11:25   #3
JSWTDI09
JSWTDI09's Avatar
You do not want VCDS-Lite. VCDS-Lite does not support CAN bus cars and all Mk5 and Mk6 cars use CAN bus communications. You will need either a Micro-CAN interface or (if you want to be able to also talk to older VWs) a Hex+CAN interface.
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old July 30th, 2012, 12:15   #4
storx
Have Fun!
Don
Thnx, didn't know that and all I had read said I just wouldn't be able to read group 99... So good thing u answered me
Da Diesel Build
Vagcom help VCDS Lite makos101 TDI 101 18 November 18th, 2014 13:08
Mk6 Style High Beam DRL on 2010 Mk5 Jetta using VCDS? FirstOrbit84 OBD Scanners 3 June 1st, 2012 14:55
VCDS Lite pkap VW MKIV-A4 TDIs (VE and PD) 1 July 14th, 2011 14:03
VCDS Lite Problems Vagtdi OBD Scanners 7 May 4th, 2011 11:22
vcds lite rwtags OBD Scanners 1 May 18th, 2010 13:42
Page generated in 0.12591 seconds with 11 queries
[Output: 63.97 Kb. compressed to 57.14 Kb. by saving 6.83 Kb. (10.67%)]
