OK fine... <disclaimer> The following is neither an endorsement nor condemnation of products and/or the suitability for use by TDI owners </disclaimer> <translation> No Flames Pleeze </translation>
After reading this thread, and others in the past, I finally just gave up and pulled my K&N figuring... what the heck, better to error on the side of safety... I have used these filters in countless cars and never found or had any problems with them. Upon removing it, I decided to snap a few pics to document the results. You decide... Is there a problem?
The filter on the intake side looked like this...
It looks as though the air is concentrating in a few spots and not drawing perfectly evenly through the entire surface of the filter. My guess is this is more a function of the airbox design than the filter.
here is the engine side of the filter...
There is no evidence of the dirt concentration on this side. The color is even throughout and showed/left no dirt to the touch.
As for the engine side of the box...
Hmmm... Can you say, "Dinner's served"?
Finally, here is the inside of the horn leading to the MAF
For the record, I have 18,000 miles on the filter, never cleaned, factory oil, running desnorkled. There was literally NO dirt anywhere on the engine side of things. Everything was clean and dry. Just shy of the white glove test, wiping the surfaces w/a clean finger left no oily residue, grime, dirt or dust.
I will offer that I
DON'T like the gasketing scheme of the K&N. The filter itself uses a hard rubber-like foam and asks you to install additional 'stick-on' gasketing on the mating surface. To top it off, you must apply a next-to-impossible 1/8" bead of grease using a small (supplied) squeeze tube which refuses to leave a consistent bead. Proper installation isn't easy with this filter.
All things considered, it appears a PROPERLY installed K&N should perform consistent with the results I found. Whether that's good enough, I'll leave up to you people to decide. For now, I'm back to paper...
