mike518_2002
2012 VW Passat Turbo Failure
Moderator Note: OP, please fill out the applicable survey information below...
Original discussion post can be found here: http://forums.tdiclub.com/showpost.php?p=4235315&postcount=685
Miles on car at failure: 38,605
Build date:
Corrective actions from dealership:
Outside air temps at failure:
Failure warning signs, if any:
Warning lights on dash/MFI:
Problems since replacement:
Repair time:
Any dealer divulged info on other incidents involving other failures:
Did the dealership perform all maintenance and on schedule:
If not dealership, what oil was used/miles on oil:
Are you the original owner of the car:
Did you baby your car or not:
Do you interrupt DPF regenerators:
How long is your daily commute:
Transmission:
Build date:
Repair time:
Transmission:
