mfsvs
Hello , I have an 2002 jetta TDI which is surging and low on power and blowing a lot of black smoke. It has 140k on it and I cleaned the intake about 20k ago . It has been running great until a couple or days ago . Checked it with a VAG-COM and code 16786(EGR excessive flow-intermittent) showed up. I removed the EGR valve , cleaned it up,checked the operation with a hand held vacuum pump and reinstalled it . Cleared the code , and the car ran great for about a day . Now code 19561 - (valve for intake manifold flap(N239) : open or short to ground P3105 - 35 - 10 - - - intermittent ) shows up . . What & where is this manifold flap valve and how do you test it ? You can clear the code ,but it comes back as soon as you start the car . Any help on this would be great . THANKS . .
