Heh, every time I'm beating my head against the wall when my computer's unhappy for whatever german reason I'll look at the 4cyl MW pump I've got sitting next to a set of 4 13mm P pump elements and wonder if tuning the governor to idle properly would be less of a hassle than dealing with the demons of EDC15.
I would definitely try to stick with the mechanical VE pump for a daily before going inline without timing adavance however I do understand the point you ment to get across
I would never ever go to a mechanical ve pump when you have ecu that can controll everything. For a Jeep conversion and for off road use mechanical is good option but for a street driven car its not. No control for timing and very limited control for afr.
Lähetetty minun PLK-L01 laitteesta Tapatalkilla
If I were able to tune the ECU myself then I'd likey agree.The speed density tune AKA MAF delete basically converts my VP pump into a VE without an AFC imo.The problem is that I don't have the interest to learn how to make my own files or search the world for the ultimate tune $$$.I can burn a program into the chips but that is where I stopped.
Alot of tuning with the VP it seems is based on everything in the engine working 100% and being predictable.As compression gets lower over time then the tune would need to be adjusted to suit for example.
I'm attempting to tune the "dinosaur" VE pump to both start my ALH engine better and to run it cleaner than a custom tune with the VP.It's quite possible that I can prove myself wrong.My old AHU powered offroad buggy performs and starts well with the VE pump, similar compression and more fueling/turbo.
